Quick release case mounts?
  • Quick release case mounts?
    Good morning all,
    I'm looking for a quick release case mounts solution to enable me to remove the VOOMPC2 case with ease.
    I have wifi which works well but sometimes need the PC inside to do work.
    I hoping for some type of elegant looking bung/cap that locks into position and squeezes to release, or similar if you get my drift .
    Cheers
    Sent from my LT30p using Tapatalk
    Vauxhall Astra SXi Car PC installed.
    I just mount mine with 2 screws, but I could get threaded inserts and use thumbscrews, or I could put bolts up through the carpeted mounting board, and use wing nuts.
      Wing nuts don't fit as there isn't enough room to spin them. I currently have the coach bolts coming through the wooden base with a securing nut, then the voom case being secured with another nut....
      Cheers,
      Dave
        I use zip ties..quick cut and its out but i have a raised mounting plate that matches the voom case under my front seat
