Andrea DA-350 Echo Cancellation?
  • Andrea DA-350 Echo Cancellation?
    The two middle pins in the DA-350's wiring harness aren't hooked up with the connection kits that I've seen. From the attached wiring diagram, it seems they're intended for echo cancellation. If the lineout from a sound card was split into these pins, would it actually perform echo cancellation?
    Click image for larger version
