Changing keypad LED lights!
  • Changing keypad LED lights!
    Is it possible to change the LED in my keypad just like its easy to change the LED in a desktop computer? If so is it the same?
    I want to change the green to blue along with my CPU
    .:@m֧p:.winamp.win98.pentiumII.10gig
    Depends on youe keyboard! Open it up and find out!
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
      Shouldn't be a problem. Most LEDs are held in to the keyboard cover, and the leads are bent to make contact with the board. They are not usually soldered. Remember that blue LEDs take about twice the voltage of red/green/yellow LEDs, so they may not work.
        They will work (lots of people change them on regular keyboards & cdroms) but they won't be as bright as they should be.
        MP3 Cavalier - http://www.mp3cavalier.com
        MP3 Grand Prix - http://www.mp3gp.com
          If you can locate the current-limiting resistor for the LED, you can replace it with a lower-resistance one and make the blue LED brighter... but these are sometimes SMD (Surface mount) and are thus a pain to replace without special tools or lots of patience!
          Jason Johnson
          Yorba Linda, California
          http://www.m2pc.com
          MPC Phase IV - *** PENDING ***
            I've replaced the green LEDs in my home keyboard with blue ones, and I really can't tell the difference in brightness.
              I did it, it looks real good, ill post pics if anyone wants me to. Blue is way better than green!
                Right, they will still be bright.. But blue LEDs usually can be used as flashlights Its almost better if they are dimmer.
                  i did it too, i went with a 3.7 volt blue led
                  let me tell you this thing is bright , it lit up the back of the car, im very happy with the results
                  Music is the language, love is the message.
                    I have blue led's for my power and hdd light on my computer. I had to put 30K ohm resistors on them to dim them a bit. Without the resistors, they put a big 8' circle of blue one the opposite wall of my room!
                    www.arbybean.com
                      I changed my custom numpad leds to very cool jumbo-leds. Other is blue & other is bright-red....
                      WINAMPCAR
                      Project almost ready
                        Hmm, guess they're making blue LEDs brighter then they used to. When they first came out, they were very dim and required about 5V to light...
                          Yes, the new blue (along with true green, and even RGB) superbright LEDs are VERY bright. I have one of those Photon keychain lights and the blue LED in it can illuminate an entire room at night. The new superbright blue are so bright at the same voltage to traditional LEDs that I've had to add a resistor just to get it down to the level of the other LEDs.
                          They even make them in tiny T1 packages also!
                          Jason Johnson
                          http://www.m2pc.com
                            im still happy with mine, god i love changing leds, next is my entire computer to blue and hyper white
                            test
                            <img>http://www.geocities.com/mclikescheese/mannycavi.jpg </img>
                              Where can I obtain these blue leds you guys speak of..
