K-Line DIAG optical Tacho show on Pc
  • K-Line DIAG optical Tacho show on Pc
    would like gladly rate on indicate to let optically.
    determined rate mph usw on k-line show on pc on a graphic surface!
    I have absolutely no idea what you just asked. Can anyone translate?
      mm i speak german!my english is very bad...
      I mean data of the k-bus on the windows screen indicate leave as with vag com ....
      some virtual instruments like kmh number of revolutions
        Still not very clear. According to this:
        http://www.elprosys.com/opisy/pdf/instr_dp2_en.pdf
        you need an RS232 cable and DiagProc II. Is that any use?
        Rob
          Are you trying to disply your tach and or speedo on the LCD?
          if not.. anyone have any info HOW to do this? BTW, its for a NON-ODBII (its ODBI) car.
          2011 Nissan Frontier SL
          AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
          OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
            yes!
            i have a golf III with k-line
              is it universal and if so where can I get one?
