Will this fan work in a 2699r case?
  • Will this fan work in a 2699r case?
    i plan on getting a 2699r case and it says that it has space for 2 40mm case fans. will this fan work? http://www.nexfan.com/ev40x40x10fa.html will this fan be adequate or is it garbage? also what is the difference between a 3pin and 4pin connector? which would i want? a epia-m mobo will go in the case.
    thanx
    matt
    Yes it will work. But there is no need to buy it, because the 2699r comes with 2 40mm fans.
    -Craig
