Using defective laptop as carputer
  • Using defective laptop as carputer
    I got this crazy idea! What about buying an used laptop with a defective screen(connect tv-out to external 7" tft) for use as a carputer?
    Pros:
    Cheap (probably, because of defective screen)
    Low power consumption (doesn't require high power inverter)
    No additional cooling required
    Takes little space!
    CRX VTEC '91 150HP, MicroATX in custom made case, PIII 600E, integrated Voodoo 3 =)
    Hey, that works but you will spend more money on a decent laptop with a defective screen then a new decent computer...you can build a small computer that is FAST, like put a xp 1800 in there for like.....$200. Rather go with the computer then laptop and if you ever need to upgrade then you can, and laptop you cant upgrade jack.
      Check out my project, did exactly that
      entire system cost (laptop, power, everything) $400
      I dare anyone to build a box with similar power and durability for under $400.... I don't need to spend $200 on an opus powersuply all I need is a $5 small circut and a $35 car adaptor for the laptop. 850Mhz is more than enough power, 512 ram is pleanty, 32meg ati m4 is more than enough... and I have 2xusb, 2x pcmcia, firewire, s-video out, vga out, 802.11b, ethernet, dvd laptops are the way to go
      http://www.mp3car.com/vbulletin/show...threadid=13818
      and seabass you can ungrade components on good laptops, I can swap out the ati m4 card for a mobile radeon, and my cpu is mmpga so I can swap it out for upto 1.13ghz and I can add ram and I can add bigger hard drives... what can't I upgrade?
      -- WireSix, Inc. --
      MP3Car Lives Here!
        Yes, but.. a regular computer will require a power supply with high power, so if i don't want to use dc-ac stuff that requires much space and power, i will have to buy an Opus, and that is 200$.. Now i can get a laptop with decent specs (though broken screen) for that price!
        edit: techm3 you took the words right out of my mouth
          Re: Using defective laptop as carputer
          I would not call this a carputer. I would call it a ghetto-hack-attempt-at-carputing.
          What im curently listening to.
          My complete carpc setup
            my advice, save save save and do it right!
            BossTone74
              do it right? maybe you should go read my project, more bang for the buck than any other setup
              -- WireSix, Inc. --
              MP3Car Lives Here!
                techm3, do you have any images of the final product? did you have a vga touchscreen to access the laptop?
                  no pictures of the finished product because it isn't finished. I still ahven't purchased the touch screen because I'm getting married and I ran out of money (wedding is in 3 days actually) anyway It will be controlled by a 7" indash touchscreen (from digitalww) otherwise everything works I'll try and take some pictures when I get a chance but everything is really hectic right now because of the upcomming wedding. After I get back from the honeymoon I'll get back to work on the project with pleanty of pictures
                  -- WireSix, Inc. --
                  MP3Car Lives Here!
                    Whats wrong with a car PC laptop?
                    Theres no right and wrong in making a car PC. As long as you build it within your required spec, so go for it if you think the price is right and its workable =)
                    Mine is based in a Compaq EVO N1000v motherboard on custom made case.
                    P4 2.0GHz (up to 2.4GHZ)
                    512MB RAM (up to 1GB)
                    30GB HDD
                    8X DVD ROM
                    ATI Radeon 7500 64 Bit - 32 MB
                    Onboard sound
                    2 x PCMCIA
                    2 x USB
                    Audio In / Out
                    Network
                    Modem
                    Serial Port
                    PS2
                    Firewire
                    Infra Red
                    Small casing, low heat, low noise, low power, HDD can tolerate bumps, no shut down during engine cranking, battery backup, can be placed somewhere hidden.
                    All for just about 250
                    Its obvious you cant butcher a new laptop, but if you can buy one with a cracked screen cheap then it make more sense.
                    Yes maybe the sound is not good enough for some but hey if thats a problem theres always a USB external sound card around such as the SB Extigy. Even a desktop PC wont have a good sound anyway unless you go for USB sound.
                    Beside desktop PC is not designed to run off battery...so ill say laptop spec parts is more suited for car PC.
                    And yes most laptop these days are uggradable for more power. When you upgrade a desktop PC for more power you find that the new parts wont work 100% on your old motherboard anyway. All you end up with is an old case, dusty PSU and the good old FDD which are hardly worth anything.
                    Wow it must be ugly seeing a tower/desktop PC in the car.
                    LOL just a thought...dont flame =)
                      AMEN!
                      -- WireSix, Inc. --
                      MP3Car Lives Here!
                        LOL I forgot to mention the SVGA out and microphone =)
                          What kind of CRACK are you smoking? LMAO That **** will kill ya man.
                            i think he is on some of those new mp3car.com crack..
                            just a thought. don't flame me either please :-) but i think he got a point. Laptop is much easier setup if you got the money. But if you have a like a lot of money to blow..like 3K. you should get like a custome desktop one for your car.. like the opus case.. that will be pimp..
                            Johnyeros
                            2003 SteelGray Mazda 6s
                            http://www.clemson.edu/~baon/loveownz.gif
                            My M6
                            Philips OptiBlue 5100Xenon Blue Light Throttle Lag Fix
                              Yeah those new type of crack is addictive, I agree
                              3K on laptop? no way....I wont butcher a new laptop for custom setup.
                              I just happen to be a laptop engineer and happen to get some free stuff, thats how my carpc came about
                              If you have a lot of money....you get a custom DIN sized P4 with built in DVD and motorised touch screen...now thats an mp3car crack baron.
                              Dont flame us either
