Windows XP Hibernating Power Question
  • Windows XP Hibernating Power Question
    Would it be ok if I left my carputer for a few hours at time with it left on hibernating? Cause my boot time is about a minute...And I am sure hibernating would be quicker. How much power does it use while it is hibernating?
    If I can't win, then I won't let you.
    You can leave it *on* for months. Hibernation uses zero power. What it does is it puts everything in the RAM onto your hard drive, so when you boot up again it just loads it back into your RAM. I recommend restarting weekly regardless because with Hibernation, Windows doesn't quite clean up after itself and your RAM will be used more and more each time. But yes, use hibernation over shutting it down.
    You also might want to check out some tweaks for making the WinXP boot faster, the first of which is to remove junk from your start up. 'Start' -> 'Run' -> 'msconfig' -> 'startup pane' and have fun! You normally don’t need anything other then your keyboard and mice drivers, if they have extended options (Like my Logitech keyboard has a bunch of extra buttons, and a driver called ‘iTouch’ which I have auto startup.)
    1993 BMW 325is - 15.2sec
      SiGmA_X is correct, you can hibernate forever. Well not you, but your computer.
      As for speeding up your boot times, be sure that you tweak the BIOS correctly. This means setting IDE devices (no auto detect), killing and memory checks or virus scans, enabeling fast boot option, etc.
      90% Done
      60W DC-DC & shutdown controller
      Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
      Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
      All in a shiny White 2000 V6 Mustang
      Click here to visit my NEW PhotoAlbum
        Awsome, I appreciate the tips guys! I will have to reconfigure my carputer now. You guys do know I am talking about while my car is off...I just wantd to make sure you guys know. Thanks again
          Yup, car on or off, you can still hibernate
          90% Done
            GuRuGoD - It's SiGmA_X
            Rom, GuRuGoD is totally right BIOS tweaks will help you for sure! There is a feature in most BIOS'es that will allow you to turn off BIOS Virus Checking (To make what GuRuGoD said perhaps a little clearer) but if you don't have the option don't worry, you probably don't have it enabled
            I would look into disabling everything on the motherboard that you don't need as well. If you have Serial-ATA and aren't using it, turn it off. Same with onboard RAID and stuff like that. Also, make your boot up order (BIOS) be just for your main hard drive, no need for floppy or CS boot once your system is running. And if you need it, you can always change it later.
              Fixed Above, sorry.
              90% Done
                Np. We all make mistakes (*Cough* Nuke *Cough*) Heh
                  90% Done
                    Oh, I got most of my stuff turned off and its pretty tweaked, but it still takes a while to boot windows, I think its the hard drive or something, I plan on taking it back up to my comp. room to work on it some more...I dont get my license for another 1 1/2 . And my stupid aunt lost the title to the car so I cant drive it at all.
                      There's not a whole lot besides turning off drives and startup processes to speed up windows. If you have all that donw and still want a faster boot, you need to look into sone faster hardware.
                      90% Done
                        Rom, what's your hardware setup looking like? And is it a fresh WinXP install? If you do that, it will make it easier to customize for a car!
                          wow 12 responces in almost an hour. we might as well be chatting on AIM!
                          90% Done
                            Why not! Hit me up on AIM @ sigma2kx if you want to talk about this faster! I'll log it so we can have a transcript. Hell, let's start a chat room! 'mp3car' is the chatroom to talk about this stuff in
                              I'm at work (shhh, dont tell anyone). I dont have aim here. Otherwise I would come chat with you
                              90% Done
