problem with Athlon and MSI
  • problem with Athlon and MSI
    Hi I have an MSI board (K7T266 Pro2) and a new Athlon XP +1700 chip. A month ago my brother somehow "fried" the old +1600 cpu I had in the comp, so I ordered a new +1700 one. The board is supposed to accept up to a +1800 so no problem with the faster cpu.
    Anyway the +1700 Athlon xp does not work in the comp. I dont understand it. The friend +1600 does boot up but crashes all the time.
    Is there something im missing?
    Im using PC2100 256 megs, a 40 gig HD, .. etc.
    and the MSI board has a VIA chipset. The +1700 processor just does not seem to work, and Im certain I am installing it properly.
    Mine needs to be updated.
    Humm.. Flash a new BIOS? Try new RAM? Make sure chip works (Try in friends comp)?
    1993 BMW 325is - 15.2sec
      well thats the thing Sigma, I dont really know anyone that has another Socket A board. I mean its kinda old . Anyway this is the second +1700 CPU I had newegg.com send me.
      And im certain the BIos is the latest. And I doubt the ram also because the comp does BOOT with teh fried +1600 chip (1.4 gig) , the cpu speed says 1050 mhz.. weird stuff. maybe I'll try flashing bois again.. thsnk sigma. BTW try the custom screen install.
        Will do on the custom screen It's a XP1700+ so it's 1700+ not a +1700, BTW
          You have to set the FSB and the CPU Multiplier in your bios to the right settings. I'm not 100% sure, but I think your FSB should be 133, and the CPU Multiplier should be 10.5 or 11 ... You will find them in the Frequency/Voltage section of the BIOS. I have an MSI KT4 Ultra mobo with a XP1800+ and if I try to set the BIOS to accept it, my system just shuts off. So I have it set as a XP1500+ right now because it's the only way it runs.
          It probably is a BIOS upgrade thing, but I built this PC with no floppy, so screw it If you don't know the proper way to flash your BIOS, you should really search for info and read up. It's a really good way to screw your system up if you don't know what you're doing. Hope this helps.
            I told him that in AIM. It's not that problem tho, it's got to be the board. I ran it past a seinor tech friend of mine, and he said "Board."
            Robb - You can flash from CD
              oh i know the fsb is 133, i dont know what the mutipler was set too BUT.. the new 1700+ cpu wont boot at all.. I'll try the new board.. it better work
                You need an Athlon XP "Palomino" (an older AMD) processor. You probably bought an XP "Thoroughbred" processor. If you look at this link , you will see that your board does not support the Thoroughbred processor.
                JustMe
                  oh damm your right. thats why it doesnt work, yes I did buy a 'thoroughbred" core processor.. what kinda messed up sh* is that. i guess i have to get a new board.
                  Thanks for taking your first post to answer my question
                    You're welcome!
                    I've been around for about a year now... Lots of good information on this site.
                    Back to lurking mode...
                    JustMe
