Overheating question
  • Overheating question
    Will my EPIA ME 6000 give any sign (shut down, beep, etc.) that it is getting too hot?
    Or will it just kill itself?
    more then likely the OS will crash or the system will reboot itself. some boards do beep when a certain temp is reached. not sure if they epia boards support that feature
    Project K4RPU73R
    Via Epia-M 9000
    256MB PC2100
    40GB IBM Travelstar
    7" Xenarc
    DeLorme Earthmate GPS
      If I boot mine while it's too hot it will just make a constant beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep sound.
      Aura MR62 (F and R)
      My Current MP3s
      IamDefiler.com
        Lytheum is correct. You should notice your OS becoming unstabe, and/or crashing befor anything dies. That is unless its SUPER HOT, but it shouldnt be
          Some bioses may have an option to shutdown when exceeding a certain temperature.
          You could also use motherboard monitor, speedfan, or similar to monitor system temps and set shutdown/warning temperatures if you're worried.
          -TJ
          Smart Playlists Plugin for RoadRunner
          CarPC - 05 Acura TL Navi (pics soon)
          Retired CarPC - 03 Infiniti Qx4
            MBM didnt work... I'll try speedfan. Are their any other good monitoring programs out there?
              My EpiaM 10000 came with the Via Flightdeck untility...check Via's website and see if it is available for download
              My Celica Carputer Install
