Shock mounts for case or HDD?
  • Shock mounts for case or HDD?
    I am curious about shock-mounting my entire case or at least the HDD. Has anyone done this? Does anyone have a good source for mounting hardware that is suitable to isolate an ITX case?
    I don't really like the idea of my HDD taking a dump and my USB cables rattling out of their plugs because I decided to take a dirt road once (not that I'd do that in my car anyway!)
    I was looking at the small elastomer mounts from Aeroflex located here but they are rated at 5lbs each. Mounting four of these under a case would certainly work, but I'm afraid the mounts will not give enough to isolate the vibration properly. Any suggestions?
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
    Yes it has been done...please do a search.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
      I use plain old rubber grommits to shock mount my harddrive:
      http://www.maplin.co.uk/products/mod...938&Products=3
      Rob
        I use longer than std 2.5" HDD screws, and between the case and the drive have four small squares of neoprene (ie wetsuit material). The screws pass through the four small square of neoprene, and offer a little protection.
        Given the shock rating of a laptop drive, it's probably a waste of time, but it also promotes airflow around the drive.
        C!
        http://carpc.riposte.net
        I reserve all rights in connection to each post I author, without exception.
          I use velcro..thats it
          Mine needs to be updated.
            samc:
            Velcro could be a bad idea. Skraggy's computer died when some velcro broke loose and caused a short as parts flew around.
            gork:
            If you're worried about cables working their way loose, securely mount the case to car body and use cable ties. I doubt you'll need to worry about the hdd. They are rated for a pretty high G factor. Plus, if it does die, you can buy a bigger one.
            -TJ
            Smart Playlists Plugin for RoadRunner
            CarPC - 05 Acura TL Navi (pics soon)
            Retired CarPC - 03 Infiniti Qx4
              I am really beating myself up over this one: My brother just took a broken (massively huge) 6 disc changer out of his 1990 range rover. The unit had snapped a few plastic gears inside and was beyond repair. I had to take it apart to get the magazine out of it and the whole thing was in this great shock suspension. It would have held a shuttle case perfectly!
              The other thing I'm definately going to need to shock mount is my slimline slot-load dvd drive. I am planning on integrating the bezel with the dash, and my plan is to cut the tabs that hold the bezel to the drive so that the drive can move independently from the dash. I have a ton of old, bad desktop cdrom drives and they have some good shock mounting gizmos in them, so I'll probably rob some of those parts for mounting the drive itself...
              MY CAR IS FOR SALE!
                Other than some small rubber bumpers that actually hold the HD in place, no shock mounts.
                Those rubber bumpers are about the thickness of car innertube...bigger than bicycle innertube.
                current projects
                  Originally posted by tejesh83
                  samc:
                  I use industial strength velcro and it holds like a mutha...
                  Aura MR62 (F and R)
                  My Current MP3s
                  IamDefiler.com
