Multi-In, Multi-Out Switch Needed
  • Multi-In, Multi-Out Switch Needed
    My FM Modulator sucks! It does a decent job as FM Modulation goes, but that still isn't good enough. I really like my HU so buying a new one (with AUX IN) does not sound like a plan to me.
    Since I'm not using my stereo internal amp, but rather using 2 amps (one for front, one for back) I thought maybe there is a switch out there that would allow me to simply choose my source.
    http://www.stevieg.org/d.php/mr2carpc/build.html
    I saw this guy doing the same thing I want to do (although with 1 amp) and wondered where I could get a switch similar to him.
    I need it to take 8 inputs and have 4 outputs.
    Anyone know of anything like this? Thanks in adavnce!
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
    4-pole changover or 4-pole double throw is what you are after:
    http://www.maplin.co.uk/products/mod...343&Products=1
    Rob
      So they make an 8 pole version? I ask because I started thinking .. I need double the inputs and outputs.... with every RCA cable there is the signal and a GROUND.. argh!
      Since there's 2 RCAs to each amp (4 wires), and I have 2 amps (so 8 wires) and I need to switch between Signal A and Signal B (16 wires) .... I need to then output all 4 RCAs (2 to each amp .. 8 wires).. So I need an 8-pole changeover.
      Lets see what I can find...
      Thanks!
      -Brad
      83 mp320i 285k
      -Brad
      83 mp320i
      99 mp323i
      _________
        Just tie all the grounds together. I don't think you need to switch the grounds, only the signals, so 4 pole would be good enough. I only switch signals in my headunit mod to add an aux-in:
        Aux-in mod
        Rob
          Putting all the grounds together still leaves me with 5 signals .. the 4 audio signals and the ground. Maybe I should find a 5-pole throw?
          -Brad
          83 mp320i 285k
          -Brad
          83 mp320i
          99 mp323i
          _________
            You tie the grounds together, and be fine with a four-pole. Me I'd get tvo four-pole instead
            My cars
              I see what you're saying .. I think .. I can tie all the grounds together and there'll be no need to send them into the switch....
              -Brad
              83 mp320i 285k
              -Brad
              83 mp320i
              99 mp323i
              _________
                Exactly.
                  Hmm .. Maplin is a UK company -- I can't seem to "checkout" and have the switch mailed to the US .. where else can I find this gizmo? Radioshack sucked and didn't have any...
                  -Brad
                  83 mp320i 285k
                  -Brad
                  83 mp320i
                  99 mp323i
                  _________
                    Digikey?
                      On my pioneer headunit you're not supposed to tie the grounds together, so read the manual if it tells you to not
                      My cars
                        He's not doing this to a headunit as its an switch selector for inputs to an amp.
                        The pioneer internal amp is able to bridge the rear two channels to power a low power 2ohm sub. Means that you can't tie the ground outputs together.
                        My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
                          I know what he is doing, it might not be suitable to tie the grounds together anyway, better to be on the safe side, right?
                          My cars
                            Is this what I want?
                            http://www.digikey.com/scripts/us/dk...106&Row=288886
                            -Brad
                            83 mp320i 285k
                            -Brad
                            83 mp320i
                            99 mp323i
                            _________
                              no, that says rotary switch
                              [H]4 Life
                              I'm a lesbian too.
                              I am for hire!
