Does the EPIA5000 support regular drives & sound cards?
  • Does the EPIA5000 support regular drives & sound cards?
    By "regular" I mean going to BestBuy and getting an off the shelf hard drive and CD ROM drive that would work in any other PC.
    OR does the EPIA5000 only support certain devices?
    -AL
    * 2000 Ford Expedition
    * EPIA M10000/512 meg RAM, Win XP PRO, 90w OPUS, 80 gig HD
    * TM-710VGT LCD, Wireless mouse, keyboard
    * M-Audio Sound Card, 2 Alumapro 10" subs, 2 PPI Amps (1kW)
    Check the data sheet / specs and tell us.
    -TJ
    Smart Playlists Plugin for RoadRunner
    CarPC - 05 Acura TL Navi (pics soon)
    Retired CarPC - 03 Infiniti Qx4
      C'mon tejesh83. If you're gonna post, might as well provide some information.
      -al-, I searched google for "Epia 5000" and came up with this link. Next to "Onboard IDE" it says it supports ATA 100/66, which includes almost any hard drive or CD-ROM that you can buy. The exception is 2.5" hard drives and slim CD-ROMs, which require a simple adapter.
        For all future spoon feeding, please PM linus. Can we make this a sticky?
        -TJ
          I have an EPIA 5000.. and I have it connected to an old WD 20 gig... ATA/66.. and I've connected it also to a newer Maxtor 40 gig.. ata/100.. both worked fine. i've also connected it with a 36x cd-rom and a 8x DVD-ROM.. again, both worked fine...
          the 5000 has an onboard sound processor... which works, and also a PCI slot that I've put an SB 128 into... and it worked...
          so I think it accepts pretty much anything standard.
          Nav
          VIA EPIA 533 MHz
          256 MB RAM
          7" Lilliput VGA Touchscreen
          20 gig HD
          Media Engine 2.1.4
          GPS - Earthmate/SA2004
          802.11b Connectivity
            I've got a Epia 5000
            So far I hooked up a 50x and 32x CDrom to it, worked fine. A 40gig WD HDD [Didn't like] and a 40gig Seagate Barra 4 which is loving it right now.
            I'm putting it in the car this weekend. It should be all ready soon
            Illusion: 2.4GHZ P4 @ 3.145GHZ | Gigabyte SINXP1394 | 256meg XMS3500 | SuperGrace 9500Pro
            PajeroPuter: Epia 5000 | 512meg PC-133 RAM | 30gig 5,400rpm HDD | 100w PSU & inverter | 7.5" Super LCD
