Adjust laptop TV OUT Have tried everything help!
  • Adjust laptop TV OUT Have tried everything help!
    Right i am at the end now, almost given up trying to resize my tvout from my laptop without any success.
    Its a PIII1000Ghz laptop with a SIS630 onboard vga card, it has a s-video output, which i use a transformer to conver from s-video to composite and then into one of Armen's screens. I have tried powerstrip, tvtool and have had no luck. It currently runs PAL 800x600 an it cuts off about 1" to 1.5" around the screen. I have SIS utility and it has the option to change tv settings however it is greyed out on my laptop which i assume means that it is not supported by this card.
    I have no idea where to go with this problem now except to change the laptop and put something else in, but this is the most expensive route that i can think of.
    Any help greatly appreciated.
    PS: Has anyone gone with AMANDA software looks very cool just not sure about shelling out $40 for something that may not be suitable.
    Adrian
    Anyone?
      I can't think of anything. You're running a regular resolution, its so weird that it does that. Are you sure its not your s-vido --->composite converter that is causing this problem?
      My first two ideas were TvTool and Powerstripper as well, so Im not much more help than that. I wouldn't replace the laptop though. Keep trying. Good luck.
        Just get a regular s-video to composite adapter. You don't need anything electrical converting the signal.
        Tom
        1993 Probe GT
        Rio Car w/20gb
          that is all i am using is an adapter no electrics! Turns out i have blow the motherboard trying to re wire the power button, dripping solder is not good!
            Ouch!!! Sorry to hear that, dude...
            Aura MR62 (F and R)
            My Current MP3s
            IamDefiler.com
