VIA 5000 -- slow boot (pre-OS)
  • VIA 5000 -- slow boot (pre-OS)
    I'm using the via 5000 with the eden 533 Mhz... and when i boot, there are a couple of things that seem to be slowing down the bios to OS transition.
    1) it says "Press <ESC> key for network boot options menu" and waits for a few seconds. is there any way to disable this? i've been through the bios settings and found nothing.
    2) i get some sort of PXE-61 Media failure message, and then PXE-61 exiting message. don't know what this is either. i can get the specific message if that'll help anyone.
    other hardware attached is just the harddrive (WD 13 gig)
    any help would be appreciated. thanks.
    Nav
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    I have the same probs, i dont think there is a BIOS option to disable the network boot screen, it never showed up before I updated my BIOS. So I would try going back a previous version or 2 of the BIOS (which is what Im gonna do)
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
      If you hit the key it says to edit the options (I forget it now.. don't have it hooked up to see) You have the option for it to boot local drives first before trying to do a PXE boot (network boot). The delay is the PXE boot rom trying to find a DHCP server to get an address and info from where to boot from.
      MP3 Cavalier - http://www.mp3cavalier.com
      MP3 Grand Prix - http://www.mp3gp.com
        I have the same MB and same issue...
        grrr....
        astral
        This is your life and it's ending one minute at a time...
          well its nice to know i'm not alone... tragic though.
          anyway, as per callahan's instructions, i hit the esc key to go to the network options... and you CAN put local drives first. EXCEPT it only holds for that boot. i'll try to get an answer out of VIA and let you guys know.
          Nav
          VIA EPIA 533 MHz
          256 MB RAM
          20 gig HD
          Media Engine 2.1.4
            I have the m10000, I know I had the pxe net boot coming up at one point.
            My car is in the shop at the moment, but I know I was abe to disable this option.
            Gizmo-
            Techonlogy on Wheels
            http://www.hjnetworks.com/car
              Nav
              Odd, it went away for good for me..
                not me, callahan what MB do u have?
                  the 5000.. I'm a little scared to even go in and look at the options to break my "good luck"
                    did you SAVE the settings
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      I'm desperate to get rid of this network boot option menu. I know this is an old thread but did anyone discover how to get achieve this. i've got an 800Mhz Epia
                      Hardware:- VIA EPIA MII 12000 LVDS 1.2Ghz : 137.95 + 512Mb PC2100 DDR Memory : 49.34 + Opus 150w Shuttle PSU: 128 + 7 Lilliput 629 Touchscreen: 173.90 + 2.5 40Gb 5200rpm Laptop Drive + Slotload Laptop CD-RW/DVD-ROM + Hauppage WinTV-PCI-FM : 53.95
                        Places to look in the BIOS setup:
                        BOOT ORDER. Make sure network isn't listed as a choice.
                        If there's an option to allow Wake On Lan, disable that, as well.
                        If there is an option to boot from network or allow network boot, make certain that's disabled as well.
                        Valid point...
                        I can't count the number of times I've tweaked settings and blindly (and also rather rapidly) exited out without saving, only to slap myself on the head and yell D'OH and then go back intot he bios to redo all the tweaks....
                        How about the Wiki?
