How can i get power in the trunk?
  • How can i get power in the trunk?
    Hello.
    I am about to install my computer in the trunk.
    where can i get the power to the trunk?
    Can i just get from back light(brake or others)?
    or
    should i bring power from directly from battery?
    or just make another connection from ciga jack?
    which one should i use? and what should i do?
    what did you guys do for power in the trunk?
    I am gonna run 350W inverter in trunk.
    thank you very much
    Started
    <A HREF="http://www.mp3car.com/usersites/zp3/" TARGET=_blank>
    http://www.mp3car.com/usersites/zp3/</A>
    Run an 8 or 10 gauge wire from the battery to the trunk. Most cars you can find a way to run it through the firewall. You may have to cut an X in a rubber seal and silicone over it once wire is run. I would also put a fuse inline about a foot from the battery connection. Not a good idea to run from break light......
    -+[MP3PC]+-
      Same thing the guy above me said.
      How I got power to the trunk was by running 6 gauge wire under the carpet. Then, in the middle of my back seat is a opening that goes to the trunk, so I just kinda snaked around into their.
      Clarion 200watt head unit w/ Aux in.
      Kicker 800watt 4 channel amp
      In a 96 Grand Prix SE.
        Just keep the power wire away from other wires. Especially the audio wires comming out of the computer and amps and such...
        http://www.jeepmp3.com/
        CarPC Stolen. Starting over.
        Ne1 recognize the avatar?
