wood
  • wood
    How do you ground the motherboard if you have a wooden case? What will potentially happen if the motherboard isn't grounded? I read through some old posts up couldn't find anything.
    Thanks to all who reply
    very good point i think you could just find the screw that grounds the motherbaord to the case and run a wire from that to the comon ground of the rest of the system if
    that's of course if the motherboard is grounded by a screw i really don't know how motherboards are grounded
      Call me weird but isnt the mobo grounded to the power supply by the black wire? It's not like its really going into your floors or anything.
      "I'm as confused as a baby in a topless bar"
        Thanks kane2g.....thats one way and u can also do it the way jkazakawich. Take a look at my setup, my box is wood and so will any other box i build from now on.
        abcd-1
        Author of CobraI and CobraII.
        For more information on the COBRA Application's please visit the link. For the latest or updated info on CobraII please click on the link. Get new updated files for CobraII here. ftp://pictures[email protected]/d:/newdlls
        You can contact me on AOL instant messenger....nick is Cenwesi
        Webpage comming soon!
        abcd-1
          The motherboard is already grounded through the black wire on the power supply. That should be all the grounding you will need. If you have problems with that setup (most likely to happen if you have an inverter), then you can use a small crimp lug to attach a grounding wire to one of the mounting screws.
          For what it's worth, my case is made of unconductive Lexan and I have never had any grounding problems.
          Aaron Cake
          London, Ontario, Canada
          Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
          Car: '86 Mazda RX-7 w/Basic Performance Upgrades
            Yup, the power supply grounds your motherboard and all other components pluged in to it (HDD, CDrom, etc.). I'm building my CarPC in to a padded plastic tool box
              Im thinking that gilly might have been asking was when you ground the case to the car to eliminate buzzing noise. If thats the case, use one of the screws off the back of the power supply to ground to. thats what ive done w/ mine and its a normal case.
              Grand aMP3
              The Grand aMP3 Project
              Car: 96 Pontiac Grand Am
              Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
