Project Idea
  • Project Idea
    i want to start a laptop carputer project, and i have some ideas.
    i will be getting a brand new laptop in about 3 weeks, and i have an alpine cda-7893 headunit which has an AUX output.
    im thinking about getting a small monochrome lcd display to scroll just the song titles, and get an RF remote to switch between songs
    i assume that because it is a laptop, i can just use a carcharger to power it, correct?
    also, will there be any way to set it up so that when i turn the ignition off, the laptop will go into hibernate mode? and when i turn the ignition on it will come back up?
    thanks guys
    You need to double check that, as you'll need an AUX input to run sound from your laptop into it.
    Should work fine, I've been enjoying my X10 mouse remote (RF) now that I found software to have it run under XP.
    Yes, but depending on the laptop model, you may need an adapter from the manufacturer (as some don't take 12Volts directly)
    Not sure on this one, definately look through your manual when you get it to see if there's any options regarding going into hibernation when it's not getting power, and coming back on when power is restored.
      This is the hardest question you asked. It's doubtful that your laptop will have any external means to switch power. Without opening it up and wiring to some internal contacts I really can't think of anything that will work for you short of hoping that your bios has some kind of 'wake up on serial/modem ring/wake on lan/usb keyboard'. If that is the case you could build a small device that emulates something appropriate to turn on the pc (pulls DCD high for serial port power, emulates keystroke for usb keyboard power-on, etc.) .. or you could use one of the ATX shutdown controllers and wire it internally across your power button's contacts.. that would probalby be the best option...
      MY CAR IS FOR SALE!
      See My Project Page for Details - 2003 BMW E46 ///M3
      Custom Dash Monitor Housing - OEM Fitment
      Custom Overhead DVD-ROM Housing in Headliner
      BMW I-Bus Integration
      My homepage with many other fun projects!
        Originally posted by tktoadstoolz
        i
        Getting it to hibernate would be really easy if you have the system plugged into the car charger at all times, you could just set the power profile to hibernate after a minute or 2 idle and running on batteries.
        Starting it up again is somewhat harder. You can probably get some sort of USB device that would allow you to bring the system out of suspend. But that would require pushing a button.
        As I run a laptop as well, my solution has been to just leave the laptop on when I turn the car off. Even if I'm gone 2 hours the batteries on the 'top won't run dry. If I'm going to be out of the car longer then 2 hours I'll suspend it and take the minute it takes to pull it out of the seat pocket and start it up by hand.
        A digital mind lost in an analog world.
        Learn to ask smart questions!
        http://www.catb.org/~esr/faqs/smart-questions.html
        My car PC: The Lost Cause!
