Multiple .M3U (playlist) files...Can it be done?
  • Multiple .M3U (playlist) files...Can it be done?
    Is there any way to have multiple playlists? like one for every band? I know it couldnt be done with the keypad program, but what about with the mouse remote or irman? Could this be done? much better than having one huge *** .m3u file!!
    Yes, can easily be done with the IrMan remote program. Can save up to 999 playlists. Well worth the $38 it costs.
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
      Is it possilbe to use more than 1 winamp plugin at a time, like the IRman + a visualation one or something?
        A keypad plug-in could load multiple playlists. It could work kind of like a jump to song key sequence would (something like the -####-). I've written a plug-in that does something like this but currently I'm streamlining the code so it's not ready for general use just yet.
        As for your second question; Winamp can run a combination of any number of general plug-ins (GEN_*.*) plus one visual one (VIS_*.*) per instance. Well, that is if they're true plug-ins. I honestly don't know if IR man uses a GEN or not.
          Yes Irman uses a general plugin, and it can be used with other plugins
            In regards to the keypad not able to work with multiple playlists. There is a plugin out there that does let you use up to 999 playlists for the keybpad. you would type enter ## enter and it would take you the the disired playlist.
            But why waist your time when the IRMan is a ton better then keypad.
            Yes you can use a visualization plugin with another plugin.
              Golaith... cuz I don't have any com portsopen for IRMan
              GR1NCH
              [email protected]
