Slimline IDE Adapter - How does it work?
  • Slimline IDE Adapter - How does it work?
    How the heck does this thing work??
    My slimeline HDD has 44 pin holes and then 4 other pins to the side.
    The adapter has the small end with 44 pins and plugs right in, but it says "pin1 (to HDD)" so I am sure it is installed facing the right direction.
    The other end has 40 larger pins for normal IDE, but the IDE cable has 1 center pinhole blocked (normal IDE). Do I need to break that pin off (some of you call it a "security pin") from the adapter so it fits or what???
    WTF?!?!
    HELP!!
    no manual? ask the store or makers
    My cars
      I bought it off Ebay... They showed it plugged right into the IDE cable, but that is not possible unless I break off this pin. I'm sure it's OK, because it isn't hooked up to anything at the other end.
        I had to do the same...It will work fine!
          I bought the exact same one also off eBay, just make sure you break off the right pin
          My OLD Carputer: http://www.mp3car.com/node/18137
          Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
            cool, I did, and it works.
