what to power my carputer?
  • what to power my carputer?
    Hey everyone, i was wondering how i should power my carputer.....power inverter(very cheap) or somethingelse, ive heard about the"opus" (i think thats the name of it) but have heard that it takes forever to get it cuz its 1 dude that does it....any sugggestions on the best way to power it.....looking to spend under $100.
    I paid $100 after taxes (Canadian $) for a Superex 600 watt filtered modified sine wave inverter. It's working excellent for me. dual plugs, low voltage alarm and shutdown, 1500 watt surge.. It's powering a desktop tower (Athlon XP 1800+, 640 mb ram, dvd rom, ~95 gb hdd storage, ATI Radeon 9000 pro, sblive value soundcard), Altec Lansing 2100 (2.1 system), small 7" CRT tv...
    I like the option of using AC power, you can plug anything into it and use it...
    TiTUS
      If under $100...? Inverter.
      Aura MR62 (F and R)
      My Current MP3s
      IamDefiler.com
        how much does that opus powersupply cost?
          $189 or something like that
          1997 Jeep Wrangler Rugged Waves
          Ebay Stuff For Sale
            If money is tight? Let me restate your question...
            If under $50? Still inverter.
            My $45 300W inverter has lasted over 3 years through Tampa summers. It will save you over $100.
            Aura MR62 (F and R)
            My Current MP3s
            IamDefiler.com
              Forget the AC-DC invertor stuff. Although some people are apprently happy with it's use (and more power to them) the limitations of this setup will start to naw away at you. I bought a DC-DC power supply from mini-box.com for 50 bucks and haven't had much problems with it. I am having some elecltrical noise that I am working on fixing but other then that it has been a great setup. I do have a 300watt invertor left in my car when I was using it with a AC power supply. Now I just use it for when I need to run 120v stuff. In the long run start of with a DC-DC power supply, you'l be much happier you did and probably save money in the long run.
              One last note is if you can afford the opus then it is a good idea to go with it. The mini-box power supply is great for the price but the opus was designed from the ground up for a car.
                inverter it is....didnt think a mothertrucking ps would be that expensive, $190 for a 150w.....bs
                  Gentlemen,
                  Two Dioes ~ 1USD
                  12v 7ah battery ~ 17 ( including Shipping)
                  82 Dolloars in pocket to spend on another gadget - priceless
                  ALIBABA - I30 99
                  Nemiah M10000, C134
                  DVD, 40Gig, 256MB DDR
                  GPS, OBD 2, Reverse Cam
                  Mute on stereo w I300 car kit
                  Liliput 7in w usb touch screen
                  Direct connect with BOSE-CD changer
                    Im suprised no one mentioned the Key Power supply?
                    It's 250 watts and works fine for 1 1/2 years. I paid $175 here on a group buy.
                    I can use it for a P4 CarPC also. (Currently P3 1Ghz)
                    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
                    GPSing - Digital Speedo
                    Relocating headunit and extending faceplate
                    Button app to Alt-Tab between two programs
                      DC-DC, DC-DC, DC-DC, DC-DC...
                      Serious skassama said it right. I'm not going to say that the following system is the best, but I am extremly happy with mine.
                      12volt 7ah battery $14 (From Fry's electronics)
                      1 Diode that handles something like 6 amps at 12volts $5
                      Ituner PW-70 DC-DC power supply. $50
                      SPRAGUE POWERLYTIC 36DX 8000UF 30VDC $13 (I paid 2 at a surplus place)
                      (http://cgi.ebay.com/ws/eBayISAPI.dll...&category=4662)
                      Wire the cap up between your 12v+ source and ground coming from your power source (IE in parrallel, not series). Or in other words, wire the Cap up with both the 12v+ and Ground.
                      Then, from your cap, put your diode on the +12volt side and then take it to your 12v 7ah battery 12v+ side. Also, continue your ground from the cap and wire that to the small battery to the ground on the battery. From the small battery you can wire up the Ituner DC-DC power supply. This setup takes almost no soldering and has eliminated all of the alternator noise problems, plus the system does not restart when starting the car, even if I crank it for a long time.
                      All told you have 82 bucks and a DC-DC power system that is efficient and simple. (If you don't have the Epia motherboard the Ituner DC-DC power supply won't work for you.)
                      About the only down side to this system is a shutdown controler but the developer of the PW 70 is supposedly working on one for the power supply. For my system at the moment, I don't need a shutdown controller so it doesn't bother me.
                        My $30 (Shipped.) eBay'd 300w/600wPeak Inverter is working great for my needs. Inverter all the way IMO, because I can also run other things off of it (Not that I am yet, but I plan on it soon.)
                        I really do like the idea of DC-DC too tho, and I need to look into it more eventually, but the price is driving me to keep with my inverter ($30 vs $190, for 2x wattage, and 120v vs 12v only)
                        1993 BMW 325is - 15.2sec
