Radeon 7000 PCI
  • Radeon 7000 PCI
    Ok, I just put in my new ATI Radeon 7000 pci video card with tv-out into my carputer system so that I can get better resolutions and dvd playback.
    The problem is that the card won't detect my TM-702L display!
    Does anybody have this card that can help me out with this problem?
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    Make sure you are using a 70Ohm RCA cable...
    I think thats the right number???
    EDIT: OK it was 75 Ohms...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
      how do i know if it's 75 ohms. The cable I am using worked with the epia's tv out fine!
        check it with a multimeter
        sometimes the radeon cards are picky
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          try to turn the screen on before you boot up the pc. My old rage128 is like that. Just a suggestion though.
          Carputer:
          MSI K7T turbo limited ed.
          AMD Duron 600
          TM - 701 ( Touchscreen and VGA kits will be added later)
          ATI Rage Fury
          looking at OPUS 150
          512 PC100
          40Gb HD
          SuSE 8.2 Professional
            I finally got it to work with another cable but the thing is that it won't pick up the lcd right away.
            I had to connnect it to my tv at home, it detected the tv, and then i switched the cable to the lcd.
            Thats the only way it would work. I also can't figure out how to get it to boot up through the tv out.
              Anybody?
                I know this has been covered many times before. I did a search for 'video 75ohm' and here is the link. click me
                Steve
