has anyone fitted a carputer into a single din
  • has anyone fitted a carputer into a single din
    has anyone fitted a carputer into a single din sized dash?
    I've been looking at these http://www.cartft.com/catalog/il/50
    Do you reckon they will fit into the slot perfectly.
    Well I am almost about too... waiting for the LCD....
    Vechile : I30 99
    Board : EPIA M 10000
    Memory : 256 MB DDR
    HD : 20 GIG
    Optical : DVD CD drive Toshiba
    BOX : C134
    PW suply : Tank (12v 7ah)
    Shutdown: Maestro.. (Looking into: Shutdown via serial and wakeup via lan )
    Sound : FM based
    GPS : USB
    DISPLAY : Liliput ( still waiting) XGA + touch USB to be fitted in console
    Front end: Looking for
    TV tuner : looking for
    Camera : looking for Reverse camera
    OBD-2 : about to aquire from Alex C. Peper
    ALIBABA - I30 99
    Nemiah M10000, C134
    DVD, 40Gig, 256MB DDR
    GPS, OBD 2, Reverse Cam
    Mute on stereo w I300 car kit
    Liliput 7in w usb touch screen
    Direct connect with BOSE-CD changer
      yeah thats what I'm going to do as well. I've ordered a lilliput screen + 12+ DC regular. Already got a 2.5" HD and slimline DVD-rom. Next on the shopping list is the case/motherboard/ plus some memory.
        You can get one from Xernac as well. They have 2 units made but not sure if they start shipping yet.
        - Lwin M. Maung
        If it's stuck, force it. If it breaks it needed replacing anyway
          very expensive
          ALIBABA - I30 99
          Nemiah M10000, C134
            I got a Casetronic Travla C134. It fits in the dash BUT you have to check the depth of the slot. The C134 is 10 inches whereas DIN slots are about 7inches so you have a 3 inch stick-out. I could overcome this by cutting the plastic back of the slot but this isnt a very clean way. Overheating might be a problem though since the 2 fans are facing upwards, and when inserted into the slot, are covered. Sure there are some holes on the back of the case but I dont think that they are enough.
            Memory for this case MUST be low profile, but be aware that most memory dimms advertised as "low-profile" arent really suitabl for the C134/136. It must be 0.8inches.
            Regards
            Time displayed in a different way!
            http://www.lares.dti.ne.jp/%7Eyugo/s.../03/index.html
            http://www.humanclock.com/
            FREE 3D Glasses: http://www.rainbowsymphony.com/freestuff.html
              hum the over heat is the really problem. I wonder how I'm going to get round that??
                These cases advertised as "DIN Sized" really mean they have the same cross section as a DIN slot. In reality, they are nearly twice as deep as the spec allows when you screw your cables into the back of them. It's very misleading. There would be no way to put a Mini-ITX motherboard into a DIN sized unit.
                Now if your dash is very very deep, you could still do it, but it'd still be much easier just to stash the box under a seat or in the glove box or something. Air flow will also be a problem inside there, so without intake/exhaust fans to move air into/out of the area behind your dash, you'll have problems.. probably
                MY CAR IS FOR SALE!
                See My Project Page for Details - 2003 BMW E46 ///M3
                Custom Dash Monitor Housing - OEM Fitment
                Custom Overhead DVD-ROM Housing in Headliner
                BMW I-Bus Integration
                My homepage with many other fun projects!
                  In addition, its just din sized....but doesnt mean its designed for automotive use (i.e. PSU input rates)
                    Where can you get only the case?
                    I got otherthings.
                    Project done in: [####################] - 85%
                    - Custom center console
                    - Custom trunk
                    Se my project here
                      www.cartft.com
                        Vechile : I30 99
                        Memory : 256 MB DDR
                        HD : 20 GIG
                        BOX : C134
                        Sound : FM based
                        GPS : USB
                        Have you installed this yet?
                        Any heat problems????
                        Iīm considering this kit to but havenīt made up my mind yet
                          Installed the c134 waiting on DWW to deliver the lcd
                          ALIBABA - I30 99
                          Nemiah M10000, C134
