Does the Nehemiah board come with a heat temp sensor
  • Does the Nehemiah board come with a heat temp sensor
    Does the Nehemiah board come with a heat temp sensor on so it can shutdown the system if it gets to hot?
    If not anyone got any ideas as to what I can use to measure the temps of the system to make sure it doesn't fry.
    I do know that it comes with a sensor, you can see the temp if you go to setup.
    As far as does it shutdown, i "guess" yes
    ALIBABA - I30 99
    Nemiah M10000, C134
    DVD, 40Gig, 256MB DDR
    GPS, OBD 2, Reverse Cam
    Mute on stereo w I300 car kit
    Liliput 7in w usb touch screen
    Direct connect with BOSE-CD changer
      you can use MBM ..i dunno about the those ITX's but i know my biostar board that im using shuts down when it hits 75C . . .happened once or twice here in FL
      2003 Mazda Protege5
      Molded Xenarc touch Screen
      Via M10000, seagate 40gb, 16x laptop dvd, RS gps
      EDAC 55w dc/dc
      homebrew shutdown controller
      2 power acoustik 10 FUBR's, A1800DB mono amp, AH600 to power mids and highs, pioneer speakers
        Its normally a function of the bios. My Gigabyte MB will shut down at a specific temp that I can choose in my bios.
        Car: 2000 Audi A4 Avant 1.8t
        Carputer 2.0: removed. Back to stock.
