Case recommendation
  • Case recommendation
    Hi
    I am still looking for an suitable housing of my carputer. the thing should be small as possible
    the case should be for the epia-M10000, with 2 PCI-cards (sound and WLAN or 2. graphiccard)
    has someone experience on the travla137?
    i like the morex cubid3677, but doesn´t offer unfortunately the necessary place
    thanks for each answer...
    guví
    The Spanish Style...
    SEAT LEON! My CARPC-Install or the thread up here
    Fundamental problem here. The Epia M10000 only has one PCI slot. Either choose a new motherboard or make some sacrifices in sound/graphics quality/features.
    You can get a USB WLAN adapter...
      corrections... you can get a riser card which will split it into two PCI slots......
      ALIBABA - I30 99
      Nemiah M10000, C134
      DVD, 40Gig, 256MB DDR
      GPS, OBD 2, Reverse Cam
      Mute on stereo w I300 car kit
      Liliput 7in w usb touch screen
      Direct connect with BOSE-CD changer
        Didn't realize that. Thanks for the correction.
          Here is a review of the Travla C137 by EpiaCenter
          "Buckethead's this guy that was raised in a chicken coop and without the bucket on his head, he's helpless"
          - "Really? Oh my god..."
            The riser card just turns the PCI card 90 degrees. They do make riser cards with two slots but this case doesn't appear to be able to support that.
              small as possible? make your own!
              I like some of those cubid cases but its just better to make your own. My latest case is an all acrylic 1/4" panels shaped into a rectable ... small as possible.
              Mine needs to be updated.
                Read the review I posted, the C137 does support a double PCI riser with small extensions. There was a note about a space issue with one of the slots in that case, however.
                  OK, the case looks like it will support the double riser. The review showed the single one.
                    If you use a 3.5" hard drive in the C137, you will lose one of the pci slots.
                    Scott
                    MCS-PC
                    Epia M-10000
                    XP Pro; 512MB; 60GB (2.5")
                    Panasonic Slot SlimDVD/CD-RW
                    7" Lilliput (Touchscreen)
                    Casetronic C137 w/ 90W PSU (Temp)
                    19V Laptop Adapter (Temp)
                      whats under the cd/dvd drive? looks like not much....
                      92 Subaru Legacy Wagon
                      Epia MII12000 :D
                      Morex 80W
                      120G External HDD
                      16x2 Charater Display
                      Creative IR Remote
                      VIA Sereniti 2000 Mini ITX Case
                      7.2Ah SLA Tank
                      PCMCIA 802.11b
                      256DDR Ram
                      Diamonds are for girls- wise men follow the stars
                        I'm wondering if a 3.5" hard drive can be mounted where the cd/dvd is located? Maybe to the underside of the slim cd/dvd mount? Is there room? This way both PCI slots could be used.
                        Scott
                        MCS-PC
                        Epia M-10000
