I've Nehemiah board but when I try to install Win2k or XP it crashes
  • I've Nehemiah board but when I try to install Win2k or XP it crashes
    I've insterted the CD and it start to inspect my hardware (blue screen) then it says starting windows. At which point it freezes and then resets.
    Why I've tried different memory, tried updating the bios and firmware of the CDROM. Anyone else got any ideas
    Maybe your power supply is too small to run your fullsize cdrom and HD.
    Mine worked fine with a laptop HD, slimline cdrom, and PW70 powersupply.
    I use it all the time with win2k.
    current projects
      it something to do with the 2.5 harddisc casue when I use a full size H/D it works fine?
        also tried another 2.5 H/D but same results :-(
        I think its something to do with tosihiba h/ds
          Some older laptop drives took more power to spin up, and were slower...maybe it is just too old for windose to use?
          I use fujitsu and IBMs
          current projects
            Inow thing it a memory problem as those board as dread full with memory as I've tried everything but a memeory swap.
