powering some usb devices
  • powering some usb devices
    hey guys
    i was wondering how can i power the digitalww touchscreen, a usb soundcard and a external dvd drive with one sub port. i also have a pcmcia usb card. that card can't power the touchscreen or the soundcard, but it can power the dvd drive. what do i do about the usb soundcard, since i'm gonna have the touchscreen plugged into the one usb port?
    project: built, updating software
    comp: 1.67 ghz AMD, 1 gig of ram, 80 gb hd
    software: nlited xp, roadrunner
    screen: TM-701L touchscreen
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    future: gps with and navigation software
    USB Hub
    with or without external power.
    -TJ
    Smart Playlists Plugin for RoadRunner
    CarPC - 05 Acura TL Navi (pics soon)
    Retired CarPC - 03 Infiniti Qx4
      WITH
      had problems running one without
      92 Subaru Legacy Wagon
      Epia MII12000 :D
      Morex 80W
      120G External HDD
      16x2 Charater Display
      Creative IR Remote
      VIA Sereniti 2000 Mini ITX Case
      7.2Ah SLA Tank
      PCMCIA 802.11b
      256DDR Ram
      Diamonds are for girls- wise men follow the stars
        A powered USB hub should let you power everything just fine. Most of them run off 5volts. Make sure you have clean power for this 5 volts because it goes right out to your devices with little to no conditioning. If it surges, you'll fry everything on the hub and possibly your computer too.
        A digital mind lost in an analog world.
        Learn to ask smart questions!
        http://www.catb.org/~esr/faqs/smart-questions.html
        My car PC: The Lost Cause!
          running it off an inverter would not be a good idea would it?
          bluetooth keyboard
          Sony Xplod cdx-m630
          SB MP3 sound card
            if you have a good power inverter, it would be better than just running it with a DC stepdown power supply. the power inverter is less likely to surge than straight through the car's electrical system.
              what if i connect everything to a surge protector off my 90 watt inverter?
              bluetooth keyboard
              Sony Xplod cdx-m630
              SB MP3 sound card
                If you use an inveter you should be more then fine. It will give you 2 levels of protection. The inveter itself, And then the wall wart that steps the power down to 5V DC. I wouldn't worry at all if you did it that way. The only thing is that using that sort of setup, you might get interference in your stereo system.
