Unmountable HD
  • Unmountable HD
    ok guys, heres what happened... i had me car in my drive way, started up pc... turned it off.. went back inside(forgot something) came backinto the car started pc.. and BAM... win xp gives me this little screen as winXP is loading...
    giveing me basically an error about ... BOOTDISK_UNMOUNTABLE
    The HD is a 80gig seagate, partitioned, im guessing its the partitions that have screwed up?
    or myabee their is a quick fix, or do i have to fdisk and start over
    It aint no family car.
    SEE MK2 At : -
    http://www.mp3car.com/vbulletin/showthread.php?t=22810
    pop the xp disc in, and go to recovery console or something like it, and use fixboot, fixmbr and scandisk
    My cars
      common problem in XP...easy fix just like jol said
      Debt as of 1/1/05: $34,354.48
      Debt as of July 4, 2007: $0.00 explanation
      I'M DEBT FREE!!
      I'm now a reasonably successful gunblogger.
        thanks guys
        SEE MK2 At : -
          can you actually believe that a microsoft fix just "works". I've never had one of those disks actually recover shiet.
          newaiz, what causes the tables to die like that?
          http://iamnot.azn.nu
            guys i had this happen again....
            i do the Fix and it happens everytime i restart the pc
            any suggestions
            is the HDD rooted?
            SEE MK2 At : -
              HDD may have failed. Best bet is to do a full format, reinstall windows and see if it happens again.
              Then again you could just go buy another HDD. Over at a place called Fry's around here they've had 200GB WD HDDs for $60 on random sales days. I'm sure you can find something like that over there.
              HomePage and Mp3Car Setup
                The way to fix this is to enter recovery console like stated above, and then enter:
                chkdsk /p [enter]
                fixboot [enter]
                exit [enter]
                Why does this happen? It happened first on my 120 gb wd drive.. Then, when I swapped it for a 200 gb seagate, I still get that blue screen.. Any ideas?
                  this happened to mine, Only problem is...the HDD just wouldnt spin up anymore *lob over shoulder*
                  Ford XR6T blueprint 4.0 L twin cam turbo.
                  Xenarc 7" touchscreen M10000 Audigy 2 NX
                  ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
                  Griffin Powermate Panasonic DVD-CDW
                  Pioneer 5x7 Four way, 2x12 pioneer subz
                  600watt 6chan USA audio AMP
