where can I buy velcro tapes from ?
  • where can I buy velcro tapes from ?
    I want to mount my carputer & inverter inside the trunk using velcros. in what kind of local shops should I look for these? Or which online company sells at unbeatable prices ?
    best
    -ccb
    I bought a 25 ft roll of industrial strength velcro at Home Depot for about $7.
      great! I'll go to homedepot tomorrow hopefully.
      how do you like the velcro? does it hold the case well ?
        yea, with that homodepot industrial velcro you could probably stick your case up on the headliner if you wanted to ... i aint ****tin.. its called velcro eXtreme .. i use it to stick my monitor to my dash..it comes in strips
          Two strips of that stuff hold my Casetronics 2699R to a vertical board in my trunk. I was going to add some plastics pipe straps for extra hold, but didn't need them. In fact, when I tried to remove the PC to do a little maintenance, the thing started warping because one side was being held so tight. So be careful when you have to unstick it.
