battery and alternator?
  • battery and alternator?
    what type of battery and alternator is recomended for powering a computer?
    Whatever comes with your vehicle is fine.
    Aaron Cake
    London, Ontario, Canada
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
      if the only extra electronics you have are the computer and display, then you can keep the factory alternator. If youve got some other things, like powered subs, amps, CB radio, cell phone, etc, you might want to upgrade the alternator. I have a 110 AMP alternator in my truck, because I have heavily tapped the electrical supply in my truck with various gadgets.
      oh, and as long as the vehicle is running while you have those accessories on, your standard battery will be fine
      Debt as of 1/1/05: $34,354.48
      Debt as of July 4, 2007: $0.00 explanation
      I'M DEBT FREE!!
      I'm now a reasonably successful gunblogger.
        What wattage is your current alternator? i upgraded my '90 mustang 75 amp to a 130 amp
          I was wondering the same question - the system I'm currently working on is a regular Intel PII-266, but with a 140/250 watt inverter (shut up Aaron ) to run a 9" color monitor...hey...you use what you got, right?
          So the stock batery/alternator in my sewing machine...er...Honda Civic will be enough? Consider many 10-minute trips back and forth to work, etc (ie: little charging time).
          ~m
          Using Napster,(rarely) Imesh, ScourExchange,(scratch that one, too), Gnutella and Freenet to load up my MP3-ized WebSurferPro... in my '96 Civic, of course :}
          BC ROCKS!!!
          **Update - WSPro is now in the rec room. Working on a new box for the car.**
          Current TEMPORARY setup... I-Jam -> Cassette Adapter -> Head Unit. PATHETIC!!!
          PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
          Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
          BC ROCKS!!!
            The 105 amp in my 95' Camero holds up just fine.
              As wizardPC said, for the most part stock alternators are fine. If you start putting in a lot of gadgets (high powered CB/HAM radio, high power (>500W) amps and subs, etc) then you may start running into problems. For just a simple DC-DC converter (yay!) or inverter (boo!) nothing else is required. My RX-7 has a wussy 70A alternator, and I run about 160W worth of audio (not a lot), the computer, a UV light (not much of a load), keyless entry, etc. With EVERYTHING on the car running, my voltage only drops slightly.
              Aaron Cake
