Mounting ideas for slimline dvd player in dash
  • Mounting ideas for slimline dvd player in dash
    Anyone have any good ideas on how to mount a slimline dvd drive in a custom dash face? I'm working with a din and a half space, planning on getting the touch screen motorized single din unit, then have the slimline dvd drive right below it. Din mounts are easy to come by, but what about slimline? In addition, since the computer will be in the back of the car, i assume i'd have to go to ide->firewire convertor right behind the slimline dvd drive, then figure out a way to feed it power, since I don't think you can run IDE very far (am I wrong?). I guess I could run power all the way from the computer to the dash so that when the computer comes on via its own means then the dvd drive would to, that would be just perfect!
    Any tips?
    Thanks,
    -Jason
    Did some reading. IDE is clearly not the way to go if mounting a cdrom at a distance. I think my best bet would be to go with an IDE to FIREWIRE convertor then running a firewire cable between the computer and the drive. I'd still probably run a power cable from the computer to the cdrom drive though...
    Oh man, this is gonna be sweeettt!
    -Jason
      I have put mine in the space where the cup holder was. The cup holder came out of the "casing", and the slimline CD drive slipped right into the gap
      I am running a USB cable, as well as 4 power cables (+12v,0v,0v,+5v) to the front of the car, which powers the USB2 hub and the USB2 to IDE adapter, and the cd drive
      Piccies
      Garry
      Co-Developer of A.I.M.E.E
      www.aimee.cc
        Hows that morex dc to dc converter treating you? Does it have any nifty features or is it just on and off? I ordered one from mini-itx.com but I haven't found too much info about it..
        -Jason
          I used a SlimDVD/Floppy mounting kit to mount one in the top Din of my dash.
          Scott
          MCS-PC
          Epia M-10000
          XP Pro; 512MB; 60GB (2.5")
          Panasonic Slot SlimDVD/CD-RW
          7" Lilliput (Touchscreen)
          Casetronic C137 w/ 90W PSU (Temp)
          19V Laptop Adapter (Temp)
            What kind of Car?
              ose-ml320, where did you get your slim slot dvd? The only ones I can find are the apple ones with the flipped power plug thing.
                Mercedes ML320
                Scott
                MCS-PC
                Epia M-10000
                  -Jason
                  For what it is...which is a basic DC-DC supply with no frills...it works pretty well Not enough power to spin up the 7200rpm desktop drive with the engine off, but other than that, it's OK. No shutdown/startup controller, no regulator on it, but it works well for now.
                  Garry
                  www.aimee.cc
                    That mounting kit is rather big.. does anyone know of a kit JUST for a slim drive? I have been searching on google and stuff for one but no luck yet...
                    XtReMoDs.com
                    Carputer Status (Not installed.)
                    -VIA M10000 N
                    -TM-7002S + TSK (7" LCD)
                    -512MB PC2700 DDR
                    -40GB 2.5" HD
                    -SB Live!
                    -Rand McNally GPS
                    -DLink FM Tuner
                    -XMRPC
                    _
                      ebay's your best friend
                      Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
                      Better than winamp. Click here for qcd player.
                        The problem that I see is that SlimDrives are for computers, so the mounts for them are going to be based upon 5.25 devices.
                        Mine is no where near that size anymore, I used a nibbler to cut it and shape it to the size I needed, and drilled a few holes where needed.
                        Scott
                        MCS-PC
                        Epia M-10000
                          nevermind i couldn't find it on ebay
                          but found it here
                          http://www.bixnet.com/usenforslcdd.html
                            but found it here
                            OMG that is the perfect thing! thanx!
                            that is just what I was looking for
                            XtReMoDs.com
                            -VIA M10000 N
                            -512MB PC2700 DDR
                            -40GB 2.5" HD
                            -SB Live!
                            -Rand McNally GPS
                            -DLink FM Tuner
                            -XMRPC
                            _
                              That IS perfect *bookmark*
                              -Jason
