Alpine Ai-Net to RS232 interface.
  • Alpine Ai-Net to RS232 interface.
    There has been some discussion over the years about interfacing to Alpine kit, namely with a view to allowing an Alpine head unit to control a custom made MP3 player (or other hardware).
    As an offshoot from another project I'm involved with (Alpine/BMW interface) I will shortly be able to offer converter boards that convert between Alpine Ai-Net protocol and RS232.
    Would anyone be interested in such a device? Assuming I were to go into production with a reasonable quantity, I would expect units to retail somewhere in the region of 30 to 50 UK pounds.
    Please note that the Alpine Ai-Net protocol is /substantially/ different to RS232 so a processor and custom transceiver hardware is required for the conversion.
    I am contemplating making available either a chipset or a small daughter board depending on interest.
    Please contact me directly if you have any views.
    Regards, Simon - spa@intravention.co.uk
    Sounds interesting to me, maybe.
    I might just stay with the H700 processor tho
    Ryan
    Just getting started........
      I know this is a REALLY old post.. But is there any progress on this?
        what exactly is RS232?
        is it still optical?
        I found this on it: http://www.camiresearch.com/Data_Com..._standard.html
        but it doesn't exactly make much sense to me
        lol
        Jan Bennett
          RS232 is IEEE1284, or Parallel, or LPT port
          PC Components:
          My work log
            mkay - makes sense then, but not needed for me!
            Jan Bennett
              RS232 is Serial interface, also known as "EIA232 Standard" - it has nothing to do with LPT or parallel. It is your Com port!
                http://www.techteam.cz/obr/tech/rs232.gif
                PC Components:
                My work log
                  http://www.twstore.com/db25mm128410.html
                  PC Components:
                  My work log
                    you have no clue what you are talking about
                    PC Components:
                    My work log
                      Why get nasty? get even, it feels better:
                      1- download this Read it, you might learn something
                      2- Go here for more info
                        No, RS232 is Serial interface
                        PowerVoice v1 | NaviVoice Source
                        GammaControl v2.4
                        SKINbedder v3
                        1995 Lexus SC300
                          yeah it is serial i second that.
                            Well I sure as hell do.
                            RS232 is NOT LPT, Printer, IEEE1284.
                            RS232 is a signaling standard used with
                            serial ports. It can come in many forms
                            and connectors, including both 25 and
                            9 pin serial (COM) ports.
                            Frodo
                            [H]4 Life
                            I'm a lesbian too.
                            I am for hire!
                              lol - wow - this turned into one hell of a discussion!
                              Jan Bennett
