USB 802.11b adapter with external antenna anyone?
  • USB 802.11b adapter with external antenna anyone?
    Does anyone know of a specific brand of USB 802.11b adapter that supports the use of an external antenna that can be mounted outside the vehicle? Most I have seen have the antenna built.
    Um, wrong forum, try this - http://forums.netstumbler.com/
    There's more info there than you could ever need!
    Laidback
    The ultimate CarPC - Wow!
      I just did a bit of research on 802.11b cards and antennas..
      Best 802.11b PCMCIA card Senao SL-2511CD PLUS EXT2
      Best external antenna for vehicle mounting 8 dBi Magnetic Mount Omni Antenna
      The best price I found for the Senao card is $75 at
      http://www.netgate.com/NL2511.html or http://www.hautespot.net/products/onlinecatalog.html
      The antenna can be found at http://www.hyperlinktech.com/web/hg2409mgu.php
      There is also a cheaper and more sturdy 5 dBi antenna at
      http://www.hyperlinktech.com/web/hg2405mgu.php
      Took me a few hours to read about all the info, but it was worth it. If I keep reading about new stuff like this I'm never going to get anything done! 8)
      Bill.
        Bill.
        Hmmm, the Senao does sound good! I wonder how it compares with the Horizon D2D thingy? http://forums.netstumbler.com/showth...&highlight=D2D Maybe better as there's no external antenna connection on the Horizon!
        Laidback
          the Orinoco USB client adapters are actually USB->PCMCIA adapters with PCMCIA Orinoco cards, surrounded by a big plastic enclosure. Break open the enclosure, and there is an antenna connector on the card
          Debt as of 1/1/05: $34,354.48
          Debt as of July 4, 2007: $0.00 explanation
          I'M DEBT FREE!!
          I'm now a reasonably successful gunblogger.
            are the 802.11 antennas wired a specific way? couldn't you just attach it to you car's radio antenna?
              An FM Broadcast-band antenna and 802.11b antenna are vastly different - the wavelength of a tuned 802.11b antenna is about 1/24 that of the FM BCB (100MHz) - and typically the 802.11b antennas are constructed to have much more gain than a simple 1/4-wave antenna like the FM antenna is. Most antennas, especially those the transmit as well as receive, are tuned over a narrow frequency range - typically only a few percent of the carrier frequency.
                Spend the extra money and get the 8dbi antenna. You will get practically twice the distance.
                Aura MR62 (F and R)
                My Current MP3s
                IamDefiler.com
