Auto Reverse Cam
  • Auto Reverse Cam
    As I was sitting here working on my center console I had an idea. I haven't implemented it yet, but I would like to switch my Lilliput to the aux composite input and automatically display the rear view camera input when reverse is engaged. Has anyone done this yet?
    Fabricator
    I've thought about it but shrugged off the idea as too hard to implement
    2004 G35 Coupe project
      It's not too hard to implement. Steal some of the 12V that activates your reverse lights and use it to power a relay. Make it such that the default position is the computer, and the powered position is the camera feed. Pretty simple actually. <this is if you use composite for both computer and camera>
      If you want to use a VGA for the computer and composite for the camera, take that 12v you stole from the reverse lights, and wire it to a relay. You'll need to hack open the display and wire to whatever button selects inputs and connect it to the relay, probably with a small timing circuit since the button probably is really a pulse and not latched.
      2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
        hard for someone like me who doesnt know **** about car electronics or electronic relays and such
          wouldn't it be easier to connect the video cable to the relay? so when power is put on the relay the composite signal from the camera is sent through instead of the signal from the PC (assuming your going through the composite input)
