Solar Power
  • Solar Power
    I've been looking @ various solar setups to keep my battery charged while computer is running and I'm away from my car. I found the solargizer from PulseTech .Seems like what i might need, but I'm not sure. Can anyone else shed light on this solar issue?
    Pulse Tech
    ------2000 S-10 Xtreme----------
    BookPC 433 5.6" LCD
    128mb ATI AIW
    18gb Laptop HD DVD
    GPS TV
    Wireless Internet
    Wireless LAN
    ***VIDEO SURVEILLANCE***
    AIM: Kinnish0 (Drop me a line)
    KinnishXtreme( IN CAR SN)
    Link To My XtremePC2001 Page
    Pic's of Install Here
    I doubt that the 1A (under ideal conditions, of course) the charger produces is enough to power an idling player, let alone charge the battery at the same time.
    Oh, and don't waste your money on PulseTech stuff. It has been proven over and over that pulse charging a lead acid battery has no measureable advantage over regular charging.
      Do you have any suggestions on what I should do in the way of solar power then?
      BookPC 433 5.6" LCD
      128mb ATI AIW
      18gb Laptop HD DVD
      GPS TV
      Wireless Internet
      Wireless LAN
        http://www.mp3car.com/cgi-bin/ultima...c&f=9&t=000066
        ODYSSEY
        Originally posted by Tidder
        Digital-Car UK|
        (\__/)
        (")_(")
          Originally posted by FreznoSmooth:
          <STRONG>Do you have any suggestions on what I should do in the way of solar power then?</STRONG>
          Don't use it? Sorry for the smart assed answer, but that seems to be the most efficient solution right now. If you want solar power, you will probably have to cover your entire hood/boot with solar cells. The power output is not worth the cost, at least to me.
            Im still not giving up, how would this work:
            http://www.radioshack.com/product.as...Fid=980%2D0699
            I think this might do the trick, what do ya'll think?
            BookPC 433 5.6" LCD
            128mb ATI AIW
            18gb Laptop HD DVD
            GPS TV
            Wireless Internet
            Wireless LAN
              Frezno,
              Give it up.
              How many watts of power does your system need to run?
              Let's pretend it is 80W.
              A panel that puts out 80W is going to cost about $400.00 (Solar panels at a discount as $5.00/watt). It is ONLY going to put this power out when the sun is directly over head. This panel is going to be 3ft x 1.5ft in size.
              So, what kind of power does your setup take?
              Probedude
              (with 300W of solar panels on his house feeding 5KW/hr worth of lead acid batteries to power my computers).
                Here you go, some REAL solar panels. And even then this may not be enough power for you.
                Solar panels
                  Im not looking use this solely to power my setup, that would be idiotic. What I'm looking to do is run my computer on standy with only the webcam motion detector going. I need something, like a solar panel, to try to make up as much as it can ( charge) to the car battery which the computer wuld be feeding off of. Im not trying to power my whole setup off a solar panel, I dont have that much money
                  BookPC 433 5.6" LCD
                  128mb ATI AIW
                  18gb Laptop HD DVD
                  GPS TV
                  Wireless Internet
                  Wireless LAN
                    So, even based on that what is your power requirements? Have you even measured it yet?
                    What I said about max power being generated in 100% direct sunlight, you are still looking for a decent size solar panel.
                    That 15W supply is not even close to 15W under real world conditions.
                      How much power does the average computer use on stand by or hibernate? Will a motion detection program be able to detect anything if the system is on stand-by?
                      I have been wondering about the possibilities of catching a thief in the act. What would be involved in starting the computer when the door is opened (or voltage through something)? Could this be accomplished by an alarm system that warns the thief? Instead of (or in addition to) warning or inducing a siren, which is normally ignored, the computer would be powered up by a trigger and start recording video or take pictures.
                      Just a few things to ponder...
                      thanks
                      Scott
