help on audio for dvd
  • help on audio for dvd
    I have a kenwood cd deck, front outputs go to a two channel amp for my
    speakers and rear outputs go to a mono amp for sub.
    I got a car dvd player that I put under the passenger seat. How
    should I hook this up to my car stereo?
    You should check the specs on the kendwood deck. There's a good possibility that there's an AUX / cd changerconnection on the back. This would be the choice way to connect into your system.
    car computer rev 5: 8" lilliput and usual suspects
      I don't have an aux, I have a cd changer control which looks like a plug at the end of a pc keyboard only bigger. Only kenwood cd changers use that plug.
        Here's a pic of the dvd player. I just don't know how to hook it up to my existing car stereo and amps. Anyone help?
        dvd player
          You should be able to find an adapter cable that plugs into the Kenwood head unit which will give you a RCA Aux input.
          I don't know what model HU you have, but here is a an example of an aux-in adapter cable I found for Kenwoods:
          http://www.justkenwood.co.uk/stock01/auxin.asp
            You can also find one here.
            System:
            Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
            Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
              Thanks, just ordered one from Crutchfield.
