Celeron Vs EPia M10000
  • Celeron Vs EPia M10000
    Ok I am back on my Carputer Kick to hell with the Law, I can shut off the monitor pretty fast.
    Now the Big question I want a Boot time under 45Seconds and a fast switch time for songs (my m5000 had about a 2 second switch time per song with ME and Xp Pro)
    So here is the question
    Celeron Vs, M10000 Vs ????
    Suggestions ??
    I might add a DVD rom later or play some DIvxx Movies when Waiting for the GF to get off work.
    Max Price I WOULD pay for computer case is 500
    VIA EPIA-M10000
    Processor:VIA C3/Eden EBGA Processor
    Chipset: VIA CLE266 North Bridge / VT8235 South Bridge
    System Memory: 1 DDR266 DIMM sockets / Up to 1GB
    VGA: Integrated VIA Unichrome AGP graphics with MPEG-2 decoder
    Expansion Slots: 1 PCI slot
    Onboard IDE: 2 x ATA133/100 Connectors
    Onboard FDD: 1 x FDD Connector
    Onboard Audio: VIA VT1616 6 Channel AC'97 CODEC
    Onboard TV Out: VIA VT1622 TV Out
    Onboard LAN: VIA VT6103 10/100 Base-T Ethernet PHY
    On Board I/O Contectors: 1 USB 2.0/1.1 Connectors for 2 Additional Ports/ 2 1394 connectors for 2 1394 ports/ Front panel audio connectors (MIC and Line-out)/ CD Audio-in Connector / SIR Connector/ CIR Connector/ Wake-on-LAN, Wake-on-Ring / 1 I2C Connector/ CPU/Power/Sys FAN / 20-pin ATX Power/ 1 x Buzzer / System Intrusion Connector
    Back Panel I/O: 1 PS2 mouse Port / 1 PS2 keyboard Port / 1 RJ 45 100/10Mb LAN Port / 2 USB 2.0/1.1 Ports / 1 Serial Ports / 1 Parallel Port / 3 Audio Jacks: line-out, line-in and mic-in/1 S-Video port/1 RCA Port/1 VGA port
    BIOS: Award BIOS, STR, ACPI, WfM 2.0, DMI 2.0 / 2/4Mbit Flash Memory
    System Monitoring & Management: CPU Temperature Monitoring / CPU Voltage Monitoring / Wake-on-LAN, Wake-on-Ring, Keyboard-Power-on, Timer-Power-on / System Power Management / AC Power Failure Recovery
    Form Factor: Mini-ATX (4 layers)
    I think u might want to wait, there is another version of the m10k comming out soon even smaller than the current m10k called nano itx. Its more like 3 1/2"...check their site and u will c it...here http://www.mini-itx.com/news/computex2003-1/
    abcd-1
      is thge new version faster or just smaller size is not a big issue I just need to be able to play my music.
        holy crap thats small! i wonder how much it would be... i could make a pc that fits in my cd holder with something that small
          The gap between songs is a function of the software you use, not your hardware. (Even a 486 is capable of playing MP3s with no gap if it uses the right software.)
            How fast of Celeron are you comparing to? I had a celeron 500 on an intel flex ATX board. Took the same memory, hdd, etc and moved over to an EPIA5000 (500MHz) and reinstalled XP clean and it was about 1/2 the speed. For example the 500mhz celeron took 30 seconds to boot XP and the EPIA took 1 minute. This was changing board and processor of course but I was a bit disappointed with the EPIA
