Testing: WD 160gig HD in -20 Celsius
  • Testing: WD 160gig HD in -20 Celsius
    Well i finally got the balls and left my X-BOX with a WD 160gig HD in my car all day today.. Temperature outside is like -20celsius (canada).
    I am going out there now to turn the x-box on to findout what happens.
    I will keep you posted.
    2k3 Max SE 6spd
    Temp setup:
    7" indash screen/Xbox running XBMC
    Carputer coming soon
    My 2003 Maxima
    Thats -4 F... i hope your drive didn't freeze or the liquid bearing inside.
    [ L ] ive. [ D ] ream. [ C ] reate.
      Okay back from the drive..
      My 7" LCD screen was frozen, but it worked.
      My xbox with the WD 160gig HD, didn't even hiccup. My xbox booted up fine, and i was able to play my divx files as if it was normal.
      ThoughtS?
      2k3 Max SE 6spd
      Temp setup:
      My 2003 Maxima
        lucky
          Originally posted by curtkay
          lucky
          No not at all. My WD has been fine in 0 degree F weather, never a problem at all. Most cold harddrive problems are with Maxtors.
            My 120 gb IBM drive will boot up at 0 degrees or higher, however at temps below 0 it generates a disk error and I have to wait about 2 minutes, reset the computer, and it boots up fine.
            My Celica Carputer Install
              Last week when we had about -15C to -20C All i hd no porblem with the harddisk (an 12G IBM 2,5" from a laptop). But the soundcard on the M10000 board went crazy!!... I didnt hear the music for the first 15min just a lot of distortion.
              But after 15min all work as it should again.
              I havent had any problem at all with my lilliput in cold wether.
              Except the touchscreen that never have worked, not even when i got the screen.
              //Peter
                Cool i was just about to post something, along the lines of "HD+Cold weather=?"
