still blowing fuses
  • still blowing fuses
    Ok..i've been doing some troubleshooting and i've narrowed the blown fuses down to 2 things. Either the barrel plug or the slide switch. Im leaning towards the slide switch though. Its a SPST heavy duty Slide Switch rated 6A at 125vac...
    could this be the problem?
    btw: im using a 1amp fuse on my partsexpress 4" tft
    Try using a 5amp fuse... and check the wire they might be making contact with each other when the vehicle moves
      and how often are u blowing fuses?
      [This message has been edited by Kain101 (edited 02-12-2001).]
        So you only blow fuses when the cord is plugged into the display?
        It is time to isolate, unhook the wireing harness from where it plugs into the LCD circuit least on mine there is a four ping plug that has the power and video input.
        then just plug your power into that part of the wiring and play with the switch, if it doesn't blow, either you have a bad LCD or a miswired plug (and now toast LCD).
        current projects
          If your blowing fuses with a SPST switch, it's not the switch. Probably the plug. Barrel (phone) plugs short when they are inserted or removed.
          Aaron Cake
          London, Ontario, Canada
          Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
          Car: '86 Mazda RX-7 w/Basic Performance Upgrades
