max temp Intel Celeron 1.3 GHz
  • max temp Intel Celeron 1.3 GHz
    does any one know the maximum safe operating temp. of a Intel Celeron 1.3 GHz ?
    nevermind I found it
    sure, thats easy to find. as soon as it starts smoking a lil, quickly turn up the AC and check the temp
    <disclaimer>the information presented here will work, however will likely result in the loss of your proccessor. perform only if you have a spare </disclaimer>
    2000 Jeep Cherokee
    -CarPC: [_____]50% complete
    -planning done, still need a few parts
    -In-dash motorized VGA is finally out, need $$$
    -Need to replace factory HU
      pfff who cares its just a celery...
      Originally posted by menudude
      thank you all for your help minus the useless post by sjlucky...
        If it's a tualatin celeron 1.3ghz it won't die if it gets too hot. The computer will freeze and the CPU'll go into shutdown mode. You might want to be careful about your north bridge however ^^
          I think for any CPU anything above 70 Degrees C is getting dangerous and will prolly shortan the life span a little. Heck I don't like my home CPU getting over 40 Deg. C.
          Aura MR62 (F and R)
          My Current MP3s
          IamDefiler.com
