no mini itx between 1ghz eden and P4 2.4Ghz?!
  • no mini itx between 1ghz eden and P4 2.4Ghz?!
    Hi guys
    been looking around for a car pc. I want more power then an Eden 1ghz (which I understand can be compared to a p2 400mhz) and too slow for DVD
    but Im not sure if a 150w opus handles a p4 2.4ghz which is the next step mini itx I found.
    running fans, and lilliput from the car 12v would unload the opus, but still a p4 need some power... right?
    (thinking of useing Dlink usb radio and the GPS usb mouse too)
    thanks
    /Henke
    _____________________________________________
    Progress [||||||||||]||/_
    Most people on here run DVD and DivX quite merrily on a 1ghz via MB.
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
      Also commell and lippert make mini-itx boards in between that range.
      Jan
      Not doing carpc anymore
        The OPUS should handle the P4 fine, I run a Anthlon XP 2000+ off a mini ATX motherboard with USB devices without a problem.
        Originally posted by Henke
        Hi guys
        thanks
        /Henke
        StreetDeck.com Developer (I am Chuck)
        Get StreetDeck at http://www.streetdeck.com
        The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
          can you please link me to your board god of cpu
          Jan, Ill check commell and lippert too!
            Hello Henke,
            The Via M10000 are fine for DVD playback, so you may not need to go the P4 route. If you do, Insight make a P4 board, same general spec as Via M10K, available here
            The Commell LV-670 takes some hunting down, but they have another coming soon, the LV-671 , that uses a mobile Pentium processor.
            The Lippert is more expensive, but rated highly... will post when I have more news on availability...
              There's always a celeron based system.
                Originally posted by lemming
                Hello Henke,
                thanks!
                saw the pentium M board, but I think pemtuim M prosessors are hard to find in sweden...
                browsed the commell site, and spoke to my bro... he uses a stationary computer, P4 3.0 radion 9800 pro, a couple of HDDs and CDrw DVDrws, and about 50 cooling fans runns from 300watt easy.
                670 useing a P4 seem too be they way to go... might be overkill today, but in 2 years you might be glad you choose a fast setup... you never know
                /henke
                  Might need one of these if you are going OPUS to P4 mainboard:
                  http://www.cablesaccessories.com/gh_PP-P4-POWER.html
                  All p4 boards I have found required the extra power-in connector from the power supply. I don't think the Opus supplies this line.
                    thanks mattm
                    not that fun to start soldering connectors on a brand new P4
