XM PCR w/Digital Output question
  • XM PCR w/Digital Output question
    Hey guys, does anyone know if the one from xmfanstore can be hooked up the normal way as well as digital ? I would assume it does but I need to make sure before I buy it and then can't use it if I decide to stay analog.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Frodo
    Yes, the analog audio still works as normal, analog and digital audio will both be active. I did the XM PCR spdif mod and I use the analog audio on my computer in the house and spdif in the car.
    Do yourself a favor and order the Blitzsafe antenna while you are at it...don't bother trying to use the directional antenna that comes with the PCR in the car.
    My Celica Carputer Install
      I am not 100% sure but it does say under 'system requirements' that the digital input is optional. In any case I had to return stuff to these guys and they took it without any issues.
      Frodo
        Thanx guys. I really appreciate it.
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          I'm going to add Optical SPDIF to my XMPCR.
          SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
          GPSing - Digital Speedo
          Relocating headunit and extending faceplate
          Button app to Alt-Tab between two programs
