Mini-ITX Beeping when I turn it on
  • Mini-ITX Beeping when I turn it on
    I got a new power supply for the mini, but now, when I turn it on, it just goes beeeeep....beeeep....beeep...and keeps doing that, nothing else. What's going on here? I couldn't find any beep codes in the manual.
    Dan
    check all the connections. Make sure the RAM is seated propperly. and try a different PSU just in case.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
      Normally it means memory, or video since the video is on board its probably the ram. if you have 2 sticks in there try replacing them, if you have 1 make sure its in the #1 slot, I don't think it matters as much anymore but its worth a try.
      CarComputer Status: New Car & Broken (Motherboard Fried)
      Owen JH | My Linux Blog | The Tech Fellows
        I agree. Constant long beeps means the BIOS does not see the memory. See this a lot.
        Tidder
        Try RevFE
