LCD / Keypad problem
  • LCD / Keypad problem
    Okay, when WinAmp starts up it loads the keypad plugin. When I push play (or if I have it setup to Autoplay) the LCD plugin starts. In order to use the keypad again WinAmp has to be the active program, but at this point the LCD plugin window is. I have no keyboard, mouse or monitor hooked up. Other people have done this and have not had any problems...how the hell did you get past this? Thanks ahead of time.
    Inside the .ini setup file for the keypad plugin, you will find a toggle for the window... switch it, so the window will NOT pop up, but the plugin will run in the background.
    Jeremy Briggs
    www.carplayer.com
      Thanks!
