5-pin switch
  • 5-pin switch
    i am taking apart a laptop to use as my car player. the power switch is labeled "SW1" on the board it is mounted on and there are five pins labeled "1, 2,3,4,5" coming out of it. Any suggestions for adding a power button in the dash? Also, has anyone managed to find +5v in a laptop, or should i just use a voltage divider and use the 12v car system?
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    use the ps/2 +5V, or IDE +5V, or usb +5V...i recommend ps/2 but whatever is easier
      haha thanks..... here i was thinking about 'where can i even find the power supply' in any case.. anyone know about that switch?
        anybody? 5 pin momentary push button switch?
          can you unsolder the switch, and mount it, or at least test it separate from the Mobo?
          current projects
            i thought about doing that, but that prevents me from taking the computer out from under the seat to put new songs/software on it. I am gonna see if i can find a similar switch i can hardwire to it today.
              I'm guessing that only two pins are used for actual power connections, and the rest are to provide stability on the board so an abused switch doesn't disconnect or crack the board. Simply find the two pins that are actually used, and solder on long wires that lead to another momentary switch/button.
