LCD messed up
  • LCD messed up
    I have a 4x20 but when I start up my 'puter only lines 1 and 3 light up. THe other two don't. I imagine this is because of a lose connection somewhere. Anyone have an idea of which pin or what i can do to remedy this?
    - JustAGuy
    mine does that, but as soon as i start lortys plugin (lorty you rule!) the lines go away and it works properly.
    "if everything is under control, you're not going fast enough!"
      Mine does the same thing, but once I start the plugin (on a good day) it works.
        justaguy, that is normal. if you want to test it to see it work, use the lcdprint.exe from cenweisi webpage
