If you use the winamp LCD plug-in, do you need a source code??
  • If you use the winamp LCD plug-in, do you need a source code??
    n/t
    nope. Just unzip the files to your WinAmp plugin directory and start up WinAmp. Press Ctrl+K and select the LCDisplayer plugin. Down @ the bottom it'll give you three choices:
    Sample all info, Screen Sim., or Panel Output.
    Select Panel Output.
    You can edit the Vis_LCDi.ini file to make it scroll faster, show different data...or as I recently found out...keep that stupid *** little window from popping up.
      THANKS!
