Help With FV24 video
  • Help With FV24 video
    I am having problems with the tv out function on my fv24 board. It might be becouse i was anxcious to see it work and I booted it with the win xp install for my old computer. I loaded the video drivers that came on the shuttle disk. That gave me a buch of advanced display options but none refering to any kind of secondary TV out. eventually i clicked something, i forget what and it had nothing to do with TV out. It then did the 15 second changing settings thing and The TV out started working but my reselution wont go any higher than 640x480. The worst part is the TV out dosent even start working till windows is almost fully loaded and it loads the video drivers. This sucks. Is there any way to get the video out to start working from the very begining of power up? I want to be able to atleast view the bios with the Tv Out. I might be able to live with 640x480 becouse ime probablly going to need to use that res anyway, but it dosent really leave any room for expansion.
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    Check the video settin gin the bios... it will be an option like VGA only, TV out only, VGA + TV Out.
    I use the last one - hopefully that will help you out.
    Jonathan
    JZ CarPC - 1998 Volvo C70
    Shuttle SV-24 Celery 400Mhz 128MB SDRAM 60GB HD DVD, 12.1" VGA TFT LCD, Sproggy/Mastero DC-DC ATX PSU, Mucha ATX shutdown controller, Co-Pilot GPS
      i found the setting you are talking about in the manual, but when i go into the bios the setting is not there. I am going to call shuttle tommorow.
      mike
        download the latest video drivers.
        MPEGBOX - Plexiglass Computer
        www.mpegbox.com
          I think Jeff meant to download the latest BIOS upgrade. Video drivers will have nothing to do with the BIOS settings.
            I did a bios update last night. That gave me the video ouput select in the bios and i can now see the post on the tv. The problem is the resloution wont go above 800x600. i know i will never need a resolution higher than that but i makes me think something is wrong. Also i cant adjust the screen size at all to fill the whole tv. There is a slider for Horizontal/vertical size, but it only has 2 positions at min and max. Every time I set it to max it resets itself to min as soon as I exit and reenter the advanced display properties? Any help would be appreciated
            mike
              tv out reslution does not go higher than
              800X600. i think only ATi cards let you do that.
              04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
              Fast car, fast PC. ;)
              http://www.arcdesigns.net/carpc/
              My TL CarPC ver2
              FSR Flash Skin w/ moving weather maps
                Does anybody out there with an fv24 board know how to expand the picture to fill the entire screen? There is a good amount of wasted space all around my screen.
                mike
                  get a program called tvtool
                    Its a good thing i am waiting and letting u guys test out this fv24 mb..... I think i will wait for the next generation mb.
                    abcd-1
                      just keep the cobra programs coming.....
