M10000 - Dead Dead Dead , 4 hours lol
  • M10000 - Dead Dead Dead , 4 hours lol
    Has anyone ever had an m10000 krap out on them , ok, so it's not dead , but the primary ide channel is , it doesn't recognize any devices anymore and i didn't do anything out of the ordinary to it , just booted it a few times , did xp updates then pfft gone , 2ndary works fine still , primary gives "verifying pool data" and then it goes to invalid disk , blah blah and press enter.. just sucks gotta rma it , just got it yesterday.. --Josh
    No.
    but I think a hint is that you did XP updates.
    Boot from the XP cd. see if it will repair the install.
    If you cannot...then put a different drive in the machine. Recheck the bios settings.
    Standard PC troubleshooting.
    current projects
      Yah.. I tried that , however , bios doesn't see it either , won't see any drive on that controller , I reinstalled xp on the drive and tried though just for a laugh and same thing of course , reset bios same thing , I have a new board on it's way.. =\
        Tried switching the cables and drives?
        Charley Ramm @ TheWiFiShop.net (ebay shop)
          Yes, =\ my first thought was omg drive died , switched the drive to 2nd channel worked fine.. at that point i knew it wasn't the drive or the cable but tried it anyway, new drive <--even a cd drive and new cable.. same results , bios doesn't see them and windows <--if i put the hd on the 2ndary channel defiantely doesn't see them
            This definately rings a bell with me! I had the same problem when building mine, f****d if I can remember how I sorted it though!
            Sorry, if I find anything in my sieve-like memory I'll let you know.....but it did work in the end!
            Laidback
            The ultimate CarPC - Wow!
              dud new board....it happens
              Ford XR6T blueprint 4.0 L twin cam turbo.
              Xenarc 7" touchscreen M10000 Audigy 2 NX
              ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
              Griffin Powermate Panasonic DVD-CDW
              Pioneer 5x7 Four way, 2x12 pioneer subz
              600watt 6chan USA audio AMP
                I had that problem also however mine turned out to be the cable. It was really strange because when I plugged my hard drive using that cable in the primary IDE channel, it would not work but when I put the same cable in the secondary it worked. At first I did not believe it but after trying consistently for two days with the same results over and over again I got fed up and pulled a cable from my desktop and that solved my problem. Funny thing is that cable now works fine in my desktop. When I'm up to it I plan on changing it before I start having problems.
                hmmmm I think I planned on changing that cable over two months ago
                2002 Chevrolet Avalanche
                Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
                http://www.mp3car.com/show-off-your-...avalanche.html
