Auto reverse camera
  • Auto reverse camera
    I'm going to be using (as soon as i get my Opus) a 7" Lilliput touchscreen with a weatherproof camera for reversing. I know the lilliput has a plug directly for the use of a camera. My question is this... how can i get to view the reverse camera as soon as i put the car in reverse??
    Is there no other option other than pressing a button on the screen to switch modes?
    AUDI A4, 2.6 V6
    Audio: Morel, Audison, Hertz, Stinger, Pioneer
    Carputer: Mirco ATX, 2.4gHz, 256ram, 80gig, 7"touchscreen, Opus
    Unfortunately, that's the end! Was good while it lasted, but gotta sell the car.
    Don't know exactly how the Lilli switches to A/V input, but I just worked out the same thing using a Cheese Box. I used that because my LCD controller is VGA in only. The Cheese Box converts the A/V signal to VGA.
    It was very simple because the button that switches from VGA to A/V input is the latching type. Meaning that when you press the button, it latches two contacts together, and displays the A/V input on the monitor. When you press the button again, it unlatches the contacts, and VGA signal is passed thru.
    I took the switch off the Cheese Box. I connected two wires to where the switch used to be, and ran them to a relay. The relay is triggered by the reverse lights on the car, so when you are in reverse, the contacts are made at the Cheese Box.
    I added a 3 position switch to allow for; A) Relay gets trigger from reverse lights; B) Relay gets trigger from constant 12V (so I can turn camera on without being in reverse); and C) No signal to relay (so I can be in reverse without the camera being on).
    I suspect the Lilli changes from one input to the other by pressing and releasing a button. Then you'd have to press and release again to get back to the other input. Is this the way it works?
      What camera did you end up using out of interest?
        I actually don't have a cam yet. But something like this is probably what I'll use. It will fit in the lens for my third brakelight. Just need to drill a hole in the red brake lens, and glue in a clear piece.
          I would probably not recommend buying the cameras from DigitalWW until you find a decent way to enclose them. The plastic domes are not sturdy and break very easily. Its just my opinion, the cameras are great other then that.
          I bought this one. Its already in a solid water proof, metal enclosure.
          EDIT: It looks like your already taking care of the enclosure part, but in case you weren't.
            It will be inside my brake light. As protected as the bulbs in there. Should be fine.
              I bought the same camera, hopefully it will be a good one. I was debating on the IR cams, but went ahead w/ this one.
              2011 Nissan Frontier SL
              AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
              OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
                Hey Ecar I have the infrared version of that camera though I did not buy it from digitalww. I am having a problems because when I connect it to my monitors I do not get any video on the lilliput 7' TS but I do get an image on my Jensen monitors in the headrest. I am stuck right now thinking of how to get this to work
                2002 Chevrolet Avalanche
                Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
                http://www.mp3car.com/show-off-your-...avalanche.html
                  Are you connecting the camera directly to the Lilli?
                  Can you connect something else to the Lilli to see that it's working?
                    just a suggestion but you might want to look into a $20 2.5 LCD Screen Controllers for XBox and use that as a rear view screen as someone suggested in another thread
                    http://www.compusa.com/products/prod...647&pfp=BROWSE
                      id support this idea
                      id love to have an automatic switching method but it would be complicated
                      theoretically, you could connect some sort of mechanism to the reverse light (either on dash or tap into the line from the rear lights) and then the mechanims goes "oo theres 'so and so' voltage running over this line, time to switch to x input" then when the wires state returns to normal the video switches back
                      this is way out of my league though so id just do a seperate lcd
                      unfortunately i missed out on this deal
                      2004 G35 Coupe project
                        Yes for troubleshoting purposes I connected it directly to the lilliput on Video 2. My computer is on the vga mode and dvd plaver uses video 1. Even when I connect the camera to video 1, I get " no video input" on the screen but when I put the dvd back, It plays. This is frustrating .
                          Diagrams & Sticky
                          Hey eCar. lovely way of connecting a backup camera. It would be much better if u could draw the whole connections diagram.
                          This must be a sticky then.
                          Keep up the good work
                          Final Touches
                          Car: 2002 Mitsubishi Magna EI
                          CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
                          Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
                            where does teh switch go
                            i agree diagrams a must!
                            [4Runna]
                            next - wifi
                              See this thread
                              http://www.mp3car.com/vbulletin/showthread.php?t=26031
