help with idea of inactivity timer
  • help with idea of inactivity timer
    refernce to this post: http://www.mp3car.com/vbulletin/showthread.php?t=20660
    Summary: want to use my carputer with standby but i leave my car sitting idle for days at a time (3+ days) and ive been advised that may drain the battery
    soo...
    would it be at all possible to have an inactivity timer that when the computer is inactive for say 2 days the computer automatically shuts down
    2004 G35 Coupe project
    A quick search yeilded this:
    http://download.com.com/3000-2094-10...ml?tag=lst-0-3
    I'm sure there's similar software out there that's free if you look hard enough.
    www.arbybean.com
      problem with software is that while in standy nothing is operational/running (afaik)
        aolhater wants a hardware timer
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          soo...
          I believe an OPUS PSU monitors the input voltage and when it gets down to a certain level it shuts off. 'course, that's not a shutdown but it will stop your battery draining!
          Laidback
          The ultimate CarPC - Wow!
            However, that is a hard power cut.
              I know, I was editing while you wrote
              Laidback
                I know nothing about the Opus, but could you somehow wire the Opus low voltage shutdown to the power button of the computer. XP has a feature that shutdowns windows when the computer's power button is pressed.
                  Originally posted by crook999
                  I XP has a feature that shutdowns windows when the computer's power button is pressed.
                  Go on, you're winding us up!!!
                  No, I don't think you can easily connect them together.....but I'm ready to be corrected!
                  Edit: Well, it could be done... if the OPUS controlled *another* shutdown controller, then when the battery gets to low, it tells the other shutdown controller to shutdown windows......
                  Laidback
                    Which, since the computer is already in standby, would turn the computer
                    right back on.
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      right back on.
                      Ah, he meant when it's already in standby?
                      Laidback
                        i spoke with chris from opus prior to all of this (a while ago) and inquired about the low battery shutoff
                        the opus psu will shut off if the battery voltage dips below 11v for more than 10 seconds
                        BUT this only happens when the computer is on, not when its in standby
